Hello Guest it is November 11, 2026, 11:15:01 PM
Author Topic: Jog ok, g code steppers just screech  (Read 8859 times)
Offline DMF
  •  17 17
« on: March 28, 2011, 08:48:43 AM »
I set the steps per to 2000, feed rate at 12. Jog either with mouse or keyboard is ok. When I try MDI and g code the x and/or steppers just screech. It sounds like their trying to run too fast. What did I miss?
  •  9,377 9,377
Re: Jog ok, g code steppers just screech
« Reply #1 on: March 28, 2011, 08:55:59 AM »
Hi and welcome to the forum.
Go back to motor tuning and reduce you velocity settings by about 20% to 30% below the point at which they stall and screech then save the setting before proceeding to the next axis etc.
« Last Edit: March 28, 2011, 08:58:17 AM by Tweakie.CNC »
« Reply #2 on: March 28, 2011, 09:05:40 AM »
... also, when jogging to set the tuning, set  to 100% (pic) to jog full rapid speed, or hold down the SHIFT key while jogging.
Russ
Offline DMF
  •  17 17
« Reply #3 on: March 28, 2011, 01:49:09 PM »
I was jogging at 100%, reducing the velocity fixed the issue. Thank you. :)
