Hello
Guest
it is
October 16, 2026, 03:44:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
project has Text text ok in LC but cuts mirror in mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: project has Text text ok in LC but cuts mirror in mach3 (Read 9359 times)
sign solutions
3
on:
March 20, 2011, 07:53:20 PM »
help
also some times the project loads outside of the "table limits" set in homing
Re: project has Text text ok in LC but cuts mirror in mach3
Reply #1 on:
March 20, 2011, 08:51:16 PM »
What you see in LC is what the code generates.
The gcode represents the piece size / project so it can be larger or outside your table limits.
Concerning mirror of the text......... check out this thread. It is not a LC problem but rather your machine setup.
http://www.machsupport.com/forum/index.php/topic,17276.msg117959.html#msg117959
BTW, see Tutorial #4 in the manual on text.
kf2qd
157
Reply #2 on:
March 21, 2011, 09:19:13 AM »
Mirroring. Does it Mirror in X or in Y? You need to alter the configuration for which ever axis is mirrored. In other words yoiu have positive and negative swapped for one axis.
Print
Pages:
1
Go Up
« previous
next »
