Hello Guest it is November 01, 2026, 12:19:51 PM
Author Topic: Posting gCode  (Read 28027 times)
Offline kolias
  •  1,165 1,165
Posting gCode
« on: March 13, 2011, 01:14:29 PM »
Mach and LC are installed in my office Laptop where I learn both software and also in my shop where I do the cutting. In both computers I first load Mach and from Mack I load LC
In my office Laptop when I finish a project in LC and I say post gcode, I switch to Mach and the gcode is there and I can see my project on the display window. However in the shop computer when I say to LC  post gcode I get the message “No Mach3 found running”. Then I have to go to file open on Mach, select the gcode and open it.
I have re installed Mach and LC in the shop computer but the results are the same
What am I doing wrong?
Nicolas
Re: Posting gCode
« Reply #1 on: March 13, 2011, 07:43:10 PM »
See Section 6.2.2 Posting Options in the manual. You can save the g code to anywhere you want.
Notice the option of sending the file to Mach when posted if the box is checked.
Offline kolias
  •  1,165 1,165
Re: Posting gCode
« Reply #2 on: March 14, 2011, 07:25:19 AM »
The box is checked to Send File to Mach3 when Posted and the directories are set correct, just verified this morning and still says Mach3 is not Running but Mach3 is running
Not that important but just wondering why
Nicolas
Re: Posting gCode
« Reply #3 on: March 14, 2011, 07:34:26 AM »
Hi Nic,
  Do you have Mach3 in the proper directory ?
 C:\Mach3
Re: Posting gCode
« Reply #4 on: March 14, 2011, 10:51:29 AM »
Did you install LC when you installed Mach?
Are you opening LC when Mach is open via the pull down?
Offline kolias
  •  1,165 1,165
Re: Posting gCode
« Reply #5 on: March 14, 2011, 08:40:18 PM »
Yes Mach3 is in the default directory C:\Mach3
Yes LC was installed when Mach was installed and I always open LC from Mach via the pull down menu
Nicolas
Re: Posting gCode
« Reply #6 on: March 14, 2011, 08:53:04 PM »
Nicolas,
Using Windows XP or 7?
Offline kolias
  •  1,165 1,165
Re: Posting gCode
« Reply #7 on: March 14, 2011, 10:39:42 PM »
I'm using XP Home
Nicolas
Re: Posting gCode
« Reply #8 on: March 15, 2011, 03:52:06 PM »
Don't know what to say....   ??? never had the problem you described.
Re: Posting gCode
« Reply #9 on: March 15, 2011, 04:19:18 PM »
I think you have this registry issue.
http://www.machsupport.com/forum/index.php/topic,17528.0/topicseen.html
Some people on the Vectric forum a few months ago were having the same issue from Vectric software.
Apparently, sometimes when Mach3 is installed, the needed registry keys are not.
