Hello
Guest
it is
November 01, 2026, 10:10:46 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Posting gCode
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Posting gCode (Read 28012 times)
kolias
1,165
Re: Posting gCode
Reply #10 on:
March 15, 2011, 05:56:49 PM »
Thank you both
Gerry I think I will install the "memoryoverride.reg" file and see the results
I will post back
Logged
Nicolas
ger21
6,295
Re: Posting gCode
Reply #11 on:
March 15, 2011, 06:01:45 PM »
I don't know what the memoryoverride.reg file is, but it's not the one I linked to, and probably not the fix to the problem your having.
Logged
kolias
1,165
Re: Posting gCode
Reply #12 on:
March 15, 2011, 06:39:24 PM »
Gerry you are a life saver.............
I first installed the “memoryoverride.reg” rebooted and did nothing
Then I installed LC alone (not from within Mach) and that did nothing
Then I installed the file from the link you provided and that did the trick. Not that it was so important but makes life much easier
Thank you both for your time
BTW the "memoryoverride.reg" is from the ArtSoft download section and I think is for people who have problems with Mack under Vista
Logged
Nicolas
Print
Pages:
1
2
Go Up
« previous
next »
