Hello Guest it is November 13, 2026, 02:03:06 PM
Author Topic: mach3 turn spindle dro not working, spindle speed changing while jogging  (Read 107875 times)
Re: mach3 turn spindle dro not working, spindle speed changing while jogging
« Reply #60 on: December 21, 2020, 02:50:34 AM »
Hello
Please, could you explain to me what difference you mean Diameter mode vs radius mode?
Where/how I can set this modes?
I'm running  R3.043.022
Offline TPS
  •  2,627 2,627
« Reply #61 on: December 21, 2020, 02:54:52 AM »
Config -> Port's&Pin's -> Turn Options -> X- Mode
do i realy have to explain the difference between Diameter and radius for a lathe user?
« Reply #62 on: December 21, 2020, 03:02:02 AM »
Sorry, I'm not real lathe user... I deal more with milling and, above all, with the retrofitting of machines.
I assume there is a difference in moving along the X axis.
I have a problem with the Z-axis ...
To this day, I have not encountered such problems ...
Offline TPS
  •  2,627 2,627
« Reply #63 on: December 21, 2020, 03:04:53 AM »
try to run .062
if i have a look to the Mach3 Changelog
https://www.machsupport.com/wp-content/uploads/2013/04/Changelist90.txt
a lot of changes for threading have been made after .022
« Reply #64 on: December 21, 2020, 03:09:33 AM »
I will try and report the result ..
« Reply #65 on: December 21, 2020, 05:11:06 AM »
MojsterMiha,
No wonder your having problems as threading was broke in that era of versions. Install / upgrade to
.062 and the problem should go away.
« Reply #66 on: December 21, 2020, 05:19:32 AM »
I will do it.
I have used an old computer with already installed and licensed MACH3 - removed from old milling machine.
On milling machine it was all OK and I did not upgrade MACH3 - my bad..
Thanks again
« Reply #67 on: January 13, 2021, 10:22:24 AM »
Finally succeeded to upgrade MACH3 to .063 version.
It works great  :)
The threads are as they actually should be.
Thank you all for your patience and all your help.
