Hello Guest it is October 14, 2026, 01:43:04 AM
Author Topic: Bridgeport is getting an overhaul  (Read 80836 times)
Re: Bridgeport is getting an overhaul
« Reply #20 on: July 30, 2011, 03:23:23 AM »
Thanks guys,
Dave, thats just the toolpath view.
« Reply #21 on: July 30, 2011, 07:07:46 AM »
Ohhhh, is that the newest form of Mach (4?)?
Is that why I see characters in the window and the background is different colors?
« Reply #22 on: July 30, 2011, 09:33:24 AM »
Yes well spotted Dave ;D That is the axis readouts in the toolpath window.
« Reply #23 on: July 30, 2011, 12:38:23 PM »
Ah, very nifty!  ;D
« Reply #24 on: August 20, 2011, 07:53:21 PM »
Well not got much  done to the Bridgeport, have a couple of small issues with the controller I will be using and I am waiting for them to get sorted before I take the panel down and fit it into the cabinet. Had thought about doing it anyway but really better if its at home as I will be able to test it out here during the evening.
Did get the control panel mounted and wiring run, cut the arm from some 4mm Alu sheet and welded it up.
« Reply #25 on: August 20, 2011, 07:55:57 PM »
Oh also got some new spindle bearings from eBay, still in sealed bags and only £34 delivered :)
Hopefully will get them fitted tomorrow.
« Reply #26 on: August 21, 2011, 07:16:05 AM »
Nice work
Is this still using Dovetails and leadscrews or has the slides and screws been upgraded too?
« Reply #27 on: August 21, 2011, 07:35:18 AM »
It was originally a BOSS 6.1 so has chromed ways and ballscrews.
« Reply #28 on: September 07, 2011, 02:47:19 PM »
Got the electrical panel fitted into the cabinet today. Wired up single phase just to test I had the wiring to the buttons and screen correct, next job will be to route the motor cables and fit and wire limits and run a heavier mains cable to the mill and it will be almost done.
« Last Edit: September 07, 2011, 02:48:58 PM by Hood »
« Reply #29 on: September 07, 2011, 03:06:41 PM »
hi Hood
Please talk about the accuracy in your machine.
Amir
**Even a clock that does not work is right twice a day**
