Hello Guest it is October 14, 2026, 01:42:56 AM
Author Topic: Bridgeport is getting an overhaul  (Read 80835 times)
Re: Bridgeport is getting an overhaul
« Reply #30 on: September 07, 2011, 03:15:51 PM »
Hi Amir, not really sure what you are meaning.
The servos encoder have 2000 line (8000 counts per rev) and the gearing on the axis is 2.5:1 with 5mm pitch screws so resolution will be 0.00025mm and I am hoping to get the tuning so I have a following error of 20 counts/20mS so that would mean the axis would trip if it was ever 0.005mm out of position.
Is that what you mean?
« Reply #31 on: September 07, 2011, 03:18:34 PM »
yes
do you used c5 ballscrew in this machine?
and pls brand?
Amir
**Even a clock that does not work is right twice a day**
« Reply #32 on: September 07, 2011, 03:20:51 PM »
It has the original Bridgeport ballscrews and I have no idea what class they are.
« Reply #33 on: September 07, 2011, 03:33:18 PM »
 :o  Looking good Hood!!!
« Reply #34 on: September 07, 2011, 03:50:43 PM »
Thanks Brett.
« Reply #35 on: September 07, 2011, 03:55:48 PM »
Looks great! Good wiring job, too!
« Reply #36 on: September 07, 2011, 04:04:52 PM »
Thanks Sam, each machine I do gets a bit neater in the wiring.
« Reply #37 on: September 07, 2011, 04:23:26 PM »
If you have been reached 5um accuracy then i must say congratulations and happy for you.
Amir
« Reply #38 on: September 07, 2011, 04:27:24 PM »
I dont think I will get anywhere near that accuracy from the machine, that is the resolution and accuracy of the servo system, there is a lot of mechanics after that and its a Bridgeport so not exactly rigid in the first place ;D
« Reply #39 on: September 09, 2011, 05:26:26 AM »
Still only have single phase connected but have tested out the Z Axis, its looking good with no backlash at all. In the vid linked below I am doing a  move of 6mm at a rapid of 5m/min.
http://www.youtube.com/watch?v=RTldulUtIOg
