Hello Guest it is November 13, 2026, 11:37:37 AM
Author Topic: single block problems  (Read 66781 times)
Re: single block problems
« Reply #40 on: November 27, 2006, 09:09:10 AM »
I think I found another bug also. When you place in feedhold while doing an -X and/or -Y move, hit start after it stops, now the -X and/or-Y move feeds at next z rate. :( ( I have edited former post with GCode file to explain better.) Feed hold affects a -X and/or -Y moves, not +. Single block effects -Z moves, not +. I just tried it with version 2.0.015.
One nice thing about all of this is I tried something else and I like it a lot. This is a work around but may be better than the original way I was doing things.
In general config. you can check program safety lockout and set up input 1 in ports and pins. This acts like a pause. Mach pauses as long as the input is made. Once released, Mach goes back to doing what it is good at, running. You don't even have to hit the start button again. I plan on setting this up as a latched switch. Push-Push.  :) I like this a lot. I will also tie this into my E-Stop circuit.
« Last Edit: November 27, 2006, 09:58:41 PM by Chaoticone »
« Reply #41 on: November 27, 2006, 09:56:50 PM »
See previous post, it has been edited.
« Reply #42 on: January 08, 2007, 09:11:38 AM »
These bugs are dead ;D. I just downloaded version 2.0.033 and any feedrate, stop, or single block issues seem to be resolved. Thanks Art.
