Hello Guest it is November 13, 2026, 03:02:27 PM
Author Topic: single block problems  (Read 66827 times)
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
Re: single block problems
« Reply #30 on: November 21, 2006, 10:44:44 PM »
Hi:
 So when its blinking reset, the collant works? Sound slike one of the enable outputs is set to the same port and pin..
any chance of that? If not, send your xml file to me.. Ill see whats up..
ARt
« Reply #31 on: November 23, 2006, 11:43:39 PM »
Can anyone run this code and confirm? See any problems?
I just downloaded the latest version(2.0.020). There is a problem with single block. If I turn on single block while in the process of a z- move it skips the next z+ then it tries to do the next x or y and the +z that it skipped together. This is in exact stop or cv mode. Here is the code I was running when it did it. I think I found another bug also. When you place in feedhold while doing an -X and/or -Y move, hit start after it stops, now the -X and/or-Y move feeds at next z rate. Feed hold affects a -X and/or -Y moves, not +. Single block effects -Z moves, not +.
G15G80G17G40G20G90G94G49G99G61G99
G1X0.0000Y0.0000F9999.0
G1Z0.0750F9999.0
G0X-4.3766Y-3.6287Z0.0750       Place in Feed Hold Here, on restart it now feeds at 8.0
G0Z0.0394
G1Z-1.0000F8.0                 Place in single block here
G0Z0.0750
G0X-7.6266
G0Z0.0394
G1Z-1.0000F8.0
G0Z0.0750
G0X-0.3766Y-0.3787
G0Z0.0394
G1Z-1.0000F8.0
G0Z0.0750
G0Y-3.6287
G0Z0.0394
G1Z-1.0000F8.0
G0Z0.0750
G0X-2.3766
G0X-2.3766Z0.0394
G1Z-1.0000F8.0
G0Z0.0750
G0X-4.3766Y-0.3787
G0Z0.0394
G1Z-1.0000F8.0
G0Z0.0750
G0X-2.3766
G0Z0.0394
G1Z-1.0000F8.0
G0Z0.0750
G0X-7.6266
G0Z0.0394
G1Z-1.0000F8.0
G0Z0.0750
G0X0.0000Y0.0000Z0.0750
G0Z0.0750
G0X0.0000Y0.0000
« Last Edit: December 02, 2006, 09:14:10 AM by Chaoticone »
« Reply #32 on: November 24, 2006, 12:04:34 AM »
I also tried this, place in feedhold, then single block. It gives me a prep. move warning later if I feedhold first. Another thing, when it blends a z and x or y move, rewind program. and start over. It goes home, then to third line, G0X-4.3766Y-3.6287Z0.0750 (first move) back home again, third line again and then starts to run.
« Last Edit: November 24, 2006, 12:06:44 AM by Chaoticone »
Offline ART
  •  1,703 1,703
« Reply #33 on: November 24, 2006, 08:13:24 AM »
Hi:
 Havent tried it yet, But Ill try to reproduce this on the weekend..
Art
« Reply #34 on: November 24, 2006, 08:24:10 AM »
Thanks Art,
    I just thought if a few people would try it we may find something in my setup and not a bug. I thought it may have something to do with the allow safe Z moves as I did not have that on the version I was running prior. I Disabled it, no Cigar, same thing.
Offline MarkC
  •  94 94
« Reply #35 on: November 24, 2006, 11:24:25 AM »
Chaoticone,
I just tried it and it did what you said. Wierd.
I did a complete uninstall including removal of all entries in the registry and all Mach files in my computer. Then I reinstalled V2.012. Coolant STILL doesn't work. I've tried changing everything in the config. I'm stumped.
Anyone got any ideas?
Mark
« Reply #36 on: November 24, 2006, 11:37:03 AM »
Mark,
   There may be a bug with the single block. I have sent you a PM.
Offline MarkC
  •  94 94
« Reply #37 on: November 24, 2006, 12:20:52 PM »
Yeah,
pretty sure theres a bug in SB.
to recap:
Was working last Saturday. Upgraded to latest version. Now coolant only comes on when in RESET even though LED shows coolant on & off properly Have changed enable, pin #, active hi/low etc. Just did a complete reinstall. Installed previous version(D1.9.084) in separate folder to see if things would work, it's picking up config from V2 so I I can't tell anything there
here are my config settings:
« Last Edit: November 24, 2006, 12:48:37 PM by MarkC »
Mark
« Reply #38 on: November 26, 2006, 08:06:28 AM »
Mark,
    Post your xml. file, screen set, and Keygrabber file if you use one. How do you turn your coolant on and off? Do you have an external button or are you just clicking on your Mach screen, or Gcode?
EDIT
If you would, save them as something like Markset1024 etc.
« Last Edit: November 26, 2006, 09:07:12 AM by Chaoticone »
Offline MarkC
  •  94 94
« Reply #39 on: November 26, 2006, 03:25:36 PM »
I'm going to start a new thread. People might think it's only about the SB problem.
Mark
