Hello Guest it is November 13, 2026, 12:14:38 PM
Author Topic: single block problems  (Read 66806 times)
Re: single block problems
« Reply #10 on: November 20, 2006, 07:24:34 PM »
Try to cut some air with a program that has no cutter comp code in it. Can you sigle block now?
Offline MarkC
  •  94 94
« Reply #11 on: November 20, 2006, 08:37:17 PM »
Yeah, I can single block in now in cycle, but it's useless. It goes to the M30 line and stays there and can't cycle start
Mark
« Reply #12 on: November 20, 2006, 08:40:03 PM »
Does it jump to M30 no matter where you are at in the program or is M30 the next line when you hit single block?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #13 on: November 21, 2006, 03:27:37 AM »
Have you got a carrige return on the end of the M30 line?
If not it needs one.
Graham.
Offline MarkC
  •  94 94
« Reply #14 on: November 21, 2006, 06:49:30 PM »
Tried it with a longer program. It goes to the M30. Yes there is a CR after the M30.
Anyone got any ideas why my coolant doesn't work after updating the version?
Mark
« Reply #15 on: November 21, 2006, 06:59:34 PM »
What version were you running? What version do you have now? You went from Mach 2- Mach 3 didn't you?
Offline MarkC
  •  94 94
« Reply #16 on: November 21, 2006, 07:16:05 PM »
Went from Mach3 D1.90.070 to V2.0.012, I just mentioned Mach2 cuz I was also having problems then. Only does it once in a while. Like I said I single blocked it twice (with D 1.9) and about 5 or 6 times after and it worked perfectly all other times.. It's frustrating because Brian said this was fixed in V2, and now I'm having more problems than ever
Mark
« Reply #17 on: November 21, 2006, 07:40:13 PM »
I know it is frustrating. These guys have got a full plate. If it makes you fell any better I have seen problems drag out for months on very expensive controllers. I'm talking thousands, and not just a few. Did you build this machine yourself? I don't know why it would have changed your system hotkeys. Or why your coolant will now work with reset. Is the version of Mach the only thing you have changed lately? I think the single block is a bug. Let's try to get the rest of it.
« Reply #18 on: November 21, 2006, 07:43:17 PM »
Did you keep a backup of your xml? if so try pasting it into the Mach folder and see if it puts you back to where you were before. Also worth a try is going back to the previous version that worked for you.
« Reply #19 on: November 21, 2006, 07:49:00 PM »
Also with regard to your mill "taking off" did you note what Graham said about your code? ie this line X.19 I.19 J0. X.0127 Y.0475 I-.095 J0. **
