Hello Guest it is November 13, 2026, 08:15:18 PM
Author Topic: NEMA 23 and 34 motor mount G-code  (Read 11491 times)
« on: February 05, 2011, 06:05:55 PM »
Does anyone have g-code for cutting NEMA 23 and NEMA34 motor mounts? This would cut a recessed circle and the four mounting holes.
thanks,
-jim
Offline DaOne
  •  236 236
Re: NEMA 23 and 34 motor mount G-code
« Reply #1 on: February 05, 2011, 10:22:45 PM »
If you can provide me with a dimensioned drawing of what you want and the tooling your using I can put it into g-code for ya.
  •  9,377 9,377
« Reply #2 on: February 06, 2011, 01:19:21 AM »
This sounds like it could be an ideal job for the wizards already built into Mach.
It does not have to be all done as one file as long as the origin is the same you could use two or three programs with tool change in between as necessary.
