Hello
Guest
it is
November 13, 2026, 08:05:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
NEMA 23 and 34 motor mount G-code
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: NEMA 23 and 34 motor mount G-code (Read 11490 times)
widpyro
91
on:
February 05, 2011, 06:05:55 PM »
Does anyone have g-code for cutting NEMA 23 and NEMA34 motor mounts? This would cut a recessed circle and the four mounting holes.
thanks,
-jim
Logged
DaOne
236
Re: NEMA 23 and 34 motor mount G-code
Reply #1 on:
February 05, 2011, 10:22:45 PM »
If you can provide me with a dimensioned drawing of what you want and the tooling your using I can put it into g-code for ya.
Logged
Tweakie.CNC
9,377
Super Kitty
Reply #2 on:
February 06, 2011, 01:19:21 AM »
This sounds like it could be an ideal job for the wizards already built into Mach.
It does not have to be all done as one file as long as the origin is the same you could use two or three programs with tool change in between as necessary.
Logged
Print
Pages:
1
Go Up
« previous
next »
