Hello Guest it is November 01, 2026, 10:10:53 AM
Author Topic: AutoCAD and LazyCam  (Read 41158 times)
AutoCAD and LazyCam
« on: February 04, 2011, 02:04:26 PM »
Hi, newbie here. I am having problems opening DXF files with LazyCam. It keeps saying "no entities found" then says file loaded but it doesn't show the image. Any suggestions? ???
Better yet, I have Inventor Professor 2011 and I can somehow import a file from to LazyCam then I would soooo happy.
« Last Edit: February 04, 2011, 02:17:26 PM by Mishawaka »
Re: AutoCAD and LazyCam
« Reply #1 on: February 04, 2011, 03:32:27 PM »
These are the steps I did when I used to use LazyCam:
I click "File-Save as" and a dialog box comes up and under "save as type", I save it as Autocad release 11/12 ASCII (dxf).
That should open up perfectly in your lazycam, Let us know how it works out-
« Last Edit: February 04, 2011, 03:34:55 PM by budman68 »
« Reply #2 on: February 04, 2011, 05:36:57 PM »
Misha, close the DXF file in AutoCad before you try to import the file into LC.   If the file is still open, LC won't import it from AutoCad.
Bob@BobsShop
« Reply #3 on: February 04, 2011, 09:06:31 PM »
I don't get the option of saving it to 11/12 ASCII (dxf). I also tried tried exporting to a different format and no go. I also tried closing AutoCAD before opening into LazyCam but no go. Does AutoCAD being 2011 make a difference? Anymore suggestions I can try?
« Reply #4 on: February 04, 2011, 09:40:44 PM »
Is you use Save As, is the last option still v12 .dxf? If so, use that.
Is this just a 2D drawing? Are you using splines?
« Reply #5 on: February 04, 2011, 10:01:52 PM »
No v12.dxf option and it is a 2D drawing. Not sure what you mean by splines. I took classes on Inventor last semester and really didn't touch AutoCAD but it came with Inventor and that is the only program I know of that I can use to save to dxf or anything that is supposed to be compatible with LazyCam. I downloaded FreeMill and noticed it opens litho files so I saved it to that but after I saved to my desktop I can't find it. I downloaded a few dxf files from the web and they open fine in LazyCam but everything I make and save won't open except in AutoCAD. The reason I need to get this to work is because whenever I try LazyCam to open a photo and get the code it distorts the code so much it isn't usable. I now kinda think I need to concentrate on learning more about AutoCAD but just not sure if that's the case.
« Last Edit: February 04, 2011, 10:04:35 PM by Mishawaka »
« Reply #6 on: February 04, 2011, 10:04:47 PM »
How bout you post one of the files "as drawn" so we might see what you're working with ?
« Reply #7 on: February 04, 2011, 10:06:14 PM »
Post a .dxf you're saving so I can look at it.
And you can't really save a 2D drawing as an .stl file.
« Reply #8 on: February 04, 2011, 10:14:56 PM »
Here it is.
« Reply #9 on: February 04, 2011, 10:19:05 PM »
AutoCAD 2009 can't even open it. You need to save it as the oldest .dxf version possible for it to have a chance of working.
What's the oldest .dxf version you can save as? try that and post again.
