Hello Guest it is November 13, 2026, 05:19:37 PM
Author Topic: Configuration Incorrect  (Read 12237 times)
« on: January 15, 2011, 02:45:11 PM »
I have just connected a new Pokeys 55 to my CNC laptop which runs Mach3 and Smooth Stepper with Windows XP. The Set Up file: PoKeys55_SetUp v2.1.17 installs OK, but when I click on the PoKeys screen icon I get the message: "This application has failed to start because the application configuration is incorrect".
I tried installing the PoKeys on my home computer and was able to configure it OK. I then plugged it into the CNC laptop and standard hotkeys were emulated correctly.
I have reinstalled the software and reset the PoKeys as described in the manual, but the same message appears.
It is the same whether the PoKeys USB is plugged in or disconnected.
Any ideas as to why the configuration software fails to start on my CNC laptop?
Re: Configuration Incorrect
« Reply #1 on: January 16, 2011, 03:01:20 PM »
are you talking about the "PoKeys Software", that Boris Makes?, if so, email him at:  Boris@poscope.com
scott
« Reply #2 on: January 22, 2011, 05:35:45 PM »
Thanks Boris for advice.
My CNC computer is not connected to web and required Windows XP Service pack 2 and NET framework 3.0 to be installed.
Problem cured
