Hello Guest it is October 21, 2026, 07:05:08 AM
Author Topic: new installation help please (driver issue)  (Read 31985 times)
Re: new installation help please (driver issue)
« Reply #10 on: January 09, 2011, 06:17:03 PM »
I had it cut 2 small 2x2 squares and it works. Let's see if it gives me anymore problems like it did before. Remember it has not been consistent.
« Reply #11 on: January 09, 2011, 06:46:44 PM »
Here is the error that the new driver gives. This just happened on the new machine. :(
« Reply #12 on: January 09, 2011, 07:08:56 PM »
Ends up I messed up - That was the USB driver 2.08.02 with the new Mach 3 v16bdg DLL plugin.
On my netbook I got the same error message yesterday and Up graded both at same time. New USB 2.08.08 and new Mach 3 v16bdg plugin. To know it came up with old driver and new plugin AGAIN, that may mean the new plugin caused my problems yesterday.
So I am now running the Beta2_v015ogx2 DLL plugin and the 2.08.08 USB driver on the new PC and see what happens.
« Reply #13 on: January 09, 2011, 07:28:01 PM »
New Mach 3 DLL and older USB driver - got through three very small scroll saw patterns. See how it goes.
« Reply #14 on: January 09, 2011, 08:07:10 PM »
Stopped in the middle of the job with no errors. So now on the new PC I am trying old USB and old mach 3 driver.
« Reply #15 on: January 09, 2011, 08:52:14 PM »
Just placed an order on amazon.com for the 32 bit version of windows 7. :(
« Reply #16 on: January 11, 2011, 05:58:56 PM »
32 bit Windows arrived.
I had more problems with smooth stepper with the new computer than I did on the netbook. I am so glad that (at least that the 32 bit version is what I need for Mach) I will get Mach 3 running with no smooth stepper and no more problems. Will run a couple of tests once Windows 7 32 bit is finished installing.
« Reply #17 on: January 11, 2011, 07:35:38 PM »
Everything works on the new PC under 32 bit Windows and NO SMOOTH STEPPER!!!!  :) :)
« Reply #18 on: January 12, 2011, 03:07:58 AM »
Well heres hoping it all stays good, the parallel port is definitely very resistant to noise.
« Reply #19 on: January 12, 2011, 08:16:58 AM »
Thanks!
