Hello Guest it is November 07, 2026, 02:32:10 AM
Author Topic: Help ! "Radial Cut with Zdepth" toolpath from mastercam makes Skip steps ??  (Read 124188 times)
Do you lose steps when just moving one axis?
If not then if you have a volt meter command a move on 2 axis and see if your power supply is managing to keep a steady volytage in to your drives.
Then same with a 3 axis move.
What are the specs of your computer and also can you attach your xml just in case there is a config issue.
ok, if one axis move it's steady, I will test the voltage tomorrow, that will takes time to open the controller.
I will attach the xml also
thanks
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
I use step motor drive from gecko
ergo full, half, 5 or 10 microstepping depending on which drive.
I use Ballscrew with 5 mm lead on X and Y.
I use step motor with NO gear ratio nor belt reduction, it's a direct drive from motor to ballscrew.
XY steps per 157.48...
Am I missing something here?
Yes, something is definitely odd in the motor setup. Also, if the Z axis is really 1" lead (25.4mm) and the X and Y axis are 5mm lead, all three are direct drive then the microstepping must be different for for the Z axis.
We need more and accurate information.
Mike
PS Is this a metric or imperial machine? I am assuming metric.
« Last Edit: January 04, 2011, 08:32:32 AM by Mike_F »
Hopefully the xml will shed some light on things.
I can not see my attachment file I just reply ?
that's funny.
here it's
« Last Edit: January 04, 2011, 06:20:09 PM by calico »
You may have to rename your xml before the forum will accept it as it only allows a file name to be used once.
I just modify the previous reply with attachment
What is your look ahead setting?
How fast is your computer?
(;-) tp
I'm sorry, how to check "look ahead setting" ?
it's Pentium 4 with 2Gb memory
