Hello Guest it is October 17, 2026, 07:41:57 AM
Author Topic: Spindle Fault and Low Lube not Working  (Read 21515 times)
« on: December 16, 2010, 06:39:38 PM »
Hello
I have a Bridgeport Series 2 mill running with AJAX control MPU11, DC3IOB board and MACH 3 software. Just found out Spindle Fault and Low Lube are not working. Spindle overload kicked out and spindle stopped but feed kept running. Low Lube does nothing. Looks like both are wired per diagram. Is this a config issue or do I need a brain to turn these on? Need some HELP!
RPM1956
Re: Spindle Fault and Low Lube not Working
« Reply #1 on: December 16, 2010, 08:23:46 PM »
HIYA RPM those are ajax specific questions might be best to ask them.
Just a thought, (;-) TP
« Reply #2 on: December 17, 2010, 06:14:46 AM »
Been there done that for 2 weeks no answer!
« Reply #3 on: December 17, 2010, 07:14:44 AM »
Any idea how they come into Mach? in other words are there port and pin numbers set up or is it another way?
« Reply #4 on: December 17, 2010, 08:34:04 AM »
No idea! I've looked through manual and found nothing on that.
RPM
« Reply #5 on: December 17, 2010, 08:54:53 AM »
What details are there, maybe if you can attach the manual and indicate which page so I dont have to trawl through it ;)
« Reply #6 on: December 17, 2010, 06:55:20 PM »
I glanced at teh manual and see not see anything specific there are a LOT of brains, ModIO and plugin callls. I'l  take another look later tonight to see IF I can spot anything for yall.
« Reply #7 on: December 17, 2010, 09:48:59 PM »
They bring those inputs in throught the PLC side so I am guessing it comes out and goes into MACH as a MODIO function thru a brain. Without the PLC ladder or the modio map it is anyone's guess
I did see where you asked on their forum . Shame they are not willing to better support you there.  Someone aught to give them a good talking to about support AFTER the sale.
« Reply #8 on: December 18, 2010, 05:20:21 PM »
Found I/O map page 10 maybe this will help. Thanks to all for the input.
rpm1956
« Reply #9 on: December 18, 2010, 05:50:14 PM »
Not sure if thats helping much from first looks as I dont see any mention of how it gets seen internally in Mach.
