Hello Guest it is October 20, 2026, 10:49:41 PM
Author Topic: Spindle Fault and Low Lube not Working  (Read 21569 times)
Re: Spindle Fault and Low Lube not Working
« Reply #10 on: December 18, 2010, 06:56:22 PM »
That show you were on the board to land the inputs shuch as low lube and spindle fault BUT it does not show how that is mapped to Mach via the Modio using the brains to transfer it to mach internally.
my guess is it uses a brain BUT what mod address is it mapping to and to what input is it mapped to in mach config???
I'll keep poking at it BUT your best bet is to call AJAX. They are the ones that created the interface and they may be the ONLY one to have that info.
