Hello
Guest
it is
November 12, 2026, 08:12:57 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
Galil
(Moderators:
smurph
kcrouch
Multi-pull Galil controllers
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Multi-pull Galil controllers (Read 9688 times)
Muskymistry
3
on:
December 13, 2010, 05:45:56 PM »
HI
Could I use a galil DMC-2040 and DMC-2020 together on Mach 3
Serial cable going from PC to the DMC-2040 and and then chaining onto the the DMC-2020
IF yes then do I do the same with the USB cable?
thanks
Musky
Logged
smurph
1,575
"That there... that's an RV."
Re: Multi-pull Galil controllers
Reply #1 on:
December 14, 2010, 12:15:08 AM »
Using two Galil controllers to gain axes is not possible.
Also, you will need to use USB for the connection instead of Serial.
Steve
Logged
Print
Pages:
1
Go Up
« previous
next »
