Hello Guest it is November 22, 2026, 09:07:10 AM
Author Topic: macropump does not work  (Read 10361 times)
« on: November 30, 2010, 02:54:03 PM »
macropump does not work in new versions MACH3.
why?
Re: macropump does not work
« Reply #1 on: November 30, 2010, 04:04:20 PM »
It does for me, check you have it enabled and have it in the correct macro folder.
« Reply #2 on: December 01, 2010, 08:59:42 AM »
I've found that I have to enable the macro pump twice to get it to stick.  First time I enable it, exit Mach then restart, I find that the macro pump in general config is still disabled.  If I enable it again, exit and restart, it stays enabled and the macro pump works.
