Hello Guest it is October 21, 2026, 02:02:27 PM
Author Topic: What Have I done?  (Read 54777 times)
What Have I done?
« on: November 05, 2006, 07:44:59 AM »
I am getting an Abnormal flashing button with a comment about "Axis are not refed to normal condition". Somehow I started this and now can't figure out how to correct the problem. OK, I am not sure what it means or what I did to cause it.
Can anyone help?
Jim
Re: What Have I done?
« Reply #1 on: November 05, 2006, 08:16:16 AM »
Is it doing this while homing? What had you changed, if any thing when it started this? Any settings?
« Reply #2 on: November 05, 2006, 08:21:11 AM »
Its flashing all the time with this warning. I am just not sure what I changed, was just setting up my mill when it started. I have a sherline with Xylotex board, no switches and in the Diagnostics page there are no lights.
I printed off the Mach3 Mill Manual but can't find anything on it.
Jim
« Reply #3 on: November 05, 2006, 08:25:45 AM »
I have not seen this. But then again I'm pretty new. Can you get the machine to home?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: November 05, 2006, 08:29:11 AM »
Hi, Jim
This is a warning ( Abnormal/Normal Condition) Yellow/Green Flashing,  When you get everything setup and working the way you want it, you can double click on it and a window will pop-up "Normalcy monitoring"  asking reset normal monitoring Yes/No.
You probally changed something axis Port's Pins, recheck every thing is set/working properly including axis ref home...........
then double click and click yes, Then you've established a normal condition.
Hope this Helps, Chip
« Reply #5 on: November 05, 2006, 08:39:37 AM »
Thanks Chip, that took care of it.
again thanks Chip and Chaoticone for the help.
Jim
« Reply #6 on: November 05, 2006, 09:08:48 AM »
You're welcome Jim.
Good job chip. You must know those machines pretty good. "Target is locked". LOL :D
Offline Chip
  •  2,055 2,055
« Reply #7 on: November 05, 2006, 09:50:44 AM »
Hi, Brett & Jim
Converted a couple machines, several in the works, You no, trip-fall-stumble-get-up, learn something every day.
It doesn't get any better than this.
Thank's Chip
« Reply #8 on: November 05, 2006, 10:26:09 AM »
Sir Chip
Well as long as I am showing my stupidity, why in my screens does the x y and z arrow show up below my table outline? In the "program run" screen with table display on, the table outline is almost at the top and the coloured arrows is almost at the bottom.
Jim
« Reply #9 on: November 05, 2006, 10:35:34 AM »
Hold down the right mouse button and move the mouse, this should let you move the screen to suit. Holding down the left will allow you to tilt and scrolling the wheel (if you have one) will zoom in and out.
