Hello Guest it is October 20, 2026, 03:09:59 PM
Author Topic: What Have I done?  (Read 54727 times)
Re: What Have I done?
« Reply #10 on: November 05, 2006, 10:37:26 AM »
Oh also a double click on the screen will put it back to default view, double click again and you will get an isometric view.
« Reply #11 on: November 05, 2006, 10:47:03 AM »
Ok thanks, that I have figured out, but why is the table outline so far away from the x y and z arrow indicator?
Jim
« Reply #12 on: November 05, 2006, 10:50:34 AM »
Maybe I am misunderstanding you, what happens if you double click on the screen?
« Reply #13 on: November 05, 2006, 10:54:14 AM »
Is this the kind of thing you are seeing?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #14 on: November 05, 2006, 10:55:57 AM »
Hi Jim
It's not stupid at all, I think what your referring to is a normal situation it just shows a view orientation marker, not a 0,0,0  position.
Hold down the left mouse key in the view screen and move it around, shows world view orientation, double click mouse again should be straight view d-clk again should give a  3D view, right mouse moves/drags image around.
Hit the Tab key, MPG-Jog window, something else to think about if you haven't found it yet.
So-many feature's, Mach3 is great, Check-out the Tutorials Documentation down-load some of it and review.
Hope this Helps, Chip
« Reply #15 on: November 05, 2006, 10:56:17 AM »
yes sir it is.
« Reply #16 on: November 05, 2006, 10:57:02 AM »
Then double click on the screen, if it takes you to an isometric view double click again.
« Reply #17 on: November 05, 2006, 11:00:42 AM »
ok if I double click it goes from the Isometric View back to table display, which again places the coloured arrows, so far down on the screen I can not see but only part of my table outline
mayby this is just a normal thing?
« Reply #18 on: November 05, 2006, 11:02:35 AM »
Nope its not normal, can you take a screenshot and post it, so we can see.
« Reply #19 on: November 05, 2006, 11:05:53 AM »
could if you tell me how, I would guess use Prt Scr, just not sure where it puts the file, never used it before
