Hello Guest it is November 13, 2026, 08:07:06 PM
Author Topic: Go Home  (Read 60326 times)
Go Home
« on: November 08, 2010, 09:45:13 AM »
Hi
Small problem, while ive been setting up my new machine i have had to hit STOP a few (hundred) times.
Thats fine works fine, but then when i hit GO HOME Mach moves in the x or y direction first gets to home position then moves up z
It does go home, but i want it to move up z before it moves x or y.
is this a Gcode problem or does Mach control the Go Home function.
Anthony.
Re: Go Home
« Reply #1 on: November 08, 2010, 10:31:41 AM »
Set up a safe Z and it should move first, you will find it from Config  menu.
Re: Go Home
« Reply #2 on: November 08, 2010, 10:59:14 AM »
thanks hood
Offline rickw
  •  110 110
Re: Go Home
« Reply #3 on: February 02, 2011, 01:32:42 PM »
How do you set up a safe Z to get it to move first?
Re: Go Home
« Reply #4 on: February 02, 2011, 01:39:15 PM »
Config Menu then Safe Z setup, you will see a box like the pic. I personally prefer using machine coords for safe Z as it is always a fixed point where as the others are not.
Offline rickw
  •  110 110
Re: Go Home
« Reply #5 on: February 02, 2011, 03:01:29 PM »
Awesome, thanks. Since you have been nice enough to bail me out of previous fixes, I thought I might ask for more advice. I'm trying to set soft limits but I can't seem to get it right. The actual limits of the machine are X=47.5", Y=18", and Z=6" but when I put these numbers in motor home/soft limits screen, I get "soft limits max<min" errors in the status screen. And I'm not sure what the other settings should be, such as reversed and home neg. I have the setting currently at X=Max 47.50/Min 0, Y=Max 18.00/Min 0, and Z=Max 0, Min 6, with Reversed and Home Neg all in red. I still get errors. Can you guide me through this?
Re: Go Home
« Reply #6 on: February 02, 2011, 03:06:38 PM »
Z Min should be a negative value so try with -6
Re: Go Home
« Reply #7 on: February 02, 2011, 03:07:06 PM »
Try a minus value for the Z axis since it goes from positive value(top) to a negative value.
Jeff
Re: Go Home
« Reply #8 on: February 02, 2011, 03:07:52 PM »
Sorry Hood, same answer at  same time.
Jeff
Re: Go Home
« Reply #9 on: February 02, 2011, 03:09:18 PM »
No need to be sorry Jeff, often happens that two people type at the same time :)
