Hello Guest it is November 24, 2026, 02:06:10 PM
Author Topic: IM NEW USER FOR MACH 3 CONTROLLER  (Read 11367 times)
« on: October 22, 2010, 02:51:12 AM »
hi im new to MACH 3  controller users , i neet to knoe if i purchase the controller for plasma & oxy cutting machine i can directly use the controller or i need to do any modifications in contriller ?
and what are the modifications need to be done ,step by step procedures ,please
which controller is suitable for plasma and oxy cutting machine LASY CAM /MACH 3
  •  9,378 9,378
Re: IM NEW USER FOR MACH 3 CONTROLLER
« Reply #1 on: October 22, 2010, 03:09:52 AM »
It is not necessary to make multiple postings of the same subject on this forum. In fact it probably has the reverse effect to what you require.
« Reply #2 on: October 22, 2010, 04:05:49 AM »
Without knowing the hardware you have/intend to use its impossible to say how much work would be involved in wiring them up to Mach.
If they are Step/Dir drives then it will be easy enough, if they are analogue then you would need to use something like DSPMC, Galil or K-Flop.
