Hello Guest it is October 23, 2026, 06:00:29 AM
Author Topic: here is pic.of my drive test ,can you help me to see...  (Read 13485 times)
« on: October 18, 2010, 03:14:38 PM »
hello
gere is my driver test pic.is this ok or bad?.
DO I NEED CHANGE SOMETHING IN MY GENERAL CONFIRURATION?
is my pulse to slow?
i dont realy dont understund this.
best regards and many thanks
Offline Sweep
  •  150 150
    • pollz.co.uk
Re: here is pic.of my drive test ,can you help me to see...
« Reply #1 on: October 18, 2010, 03:21:17 PM »
You seem to have posted in dxf format. Was this intentional?
...Sweep
p.s. how do you spell 'intentional/intensional' as neither seem to look right?
« Last Edit: October 18, 2010, 03:23:54 PM by Sweep »
« Reply #2 on: October 18, 2010, 03:49:47 PM »
i was bmp but didnt work.
can you open dxf.internationl
Offline Sweep
  •  150 150
    • pollz.co.uk
« Reply #3 on: October 18, 2010, 04:08:14 PM »
I can, but the dxf files are only text files to the jpg files on your desktop. None of the files contain any information only file locations on your computer
It would be better if you saved the information as pdf as anyone should be able to open those but you may be limiting your audience posting in dxf
...Sweep
« Reply #4 on: October 18, 2010, 04:32:16 PM »
Download WisdomSoft ScreenHunter free version and install, change the file type to JPG then configure the rest to your preference. Run the DriverTest and capture the image you wish and attach to the forum. If it doesnt attach at first it may be because there is already a file with that name on the forum. Change to a name such as OsmanDrivetest1.jpg and it should be ok.
« Reply #5 on: October 18, 2010, 04:42:09 PM »
hello thank to all of you,i know where is the problem with my pic.
hood,hello-can you answer to me i sent to you privat megase on the other forum cncz.
what you think about my problem?
regards
« Reply #6 on: October 18, 2010, 04:46:39 PM »
I have not had a PM from you as far as I know.
« Reply #7 on: October 18, 2010, 05:51:54 PM »
hello
i would like hear your opinnion about status of my driver test.
i will send tomorow pictures.
regards
