Hello Guest it is September 28, 2026, 08:39:32 PM
Author Topic: how accurate is your diy cnc machine  (Read 11350 times)
« on: October 17, 2010, 05:36:14 PM »
Hi
I`m trying to get a feel for what I could expect from a diy cnc regarding accuracy.
Re: how accurate is your diy cnc machine
« Reply #1 on: October 17, 2010, 06:07:57 PM »
Hmm.....loaded question........
All depends on the components of the machine and how you use it.
« Reply #2 on: October 17, 2010, 06:17:08 PM »
Hi
Something like a hole location to another hole. How close to the print are the holes.
« Reply #3 on: October 17, 2010, 06:24:32 PM »
Only as accurate as your machine, tooling, setup, and applied experience.
Mach controller is more accurate than anything you will build.
Your machine may move the drill within , say .0001" center to center of the holes, but that dosen't mean you
will hold that tolerance in actual practice.
