Hello Guest it is November 08, 2026, 03:10:09 AM
Author Topic: How to add LED's to Control Panel for Jog Modes.  (Read 14311 times)
Offline johnv
  •  43 43
« on: September 30, 2010, 04:21:32 PM »
Hi All,
I added pushbuttons to my control panel for Jog Cont. and Jog Step. Now I would like to add leds so I know which is active. I wired an led with a 220 ohm resister from 5vdc source to BOB2  pin1. Then in Ports & Pins/Output/, I choose  Output2 and entered 2 for ports, and 1 for pins, and choose Active low. Wrote a brain with Jog Cont Led as input, to Pass Signal/No Operation to Output2. The brains switches on when I'm in JogCont, but the led always stays lit. What am I doing wrong?
Johnv
Re: How to add LED's to Control Panel for Jog Modes.
« Reply #1 on: September 30, 2010, 04:32:45 PM »
Can  you attach the Brain please.
Offline johnv
  •  43 43
« Reply #2 on: September 30, 2010, 05:07:30 PM »
Hood,
I spent the last 15 min trying to figure out how to attach a file. Would you tell me how this is done?
Johnv
« Reply #3 on: September 30, 2010, 05:09:44 PM »
Additional options button on the reply page.
Offline johnv
  •  43 43
« Reply #4 on: September 30, 2010, 05:15:28 PM »
Hood,
Thanks!
Johnv
« Reply #5 on: September 30, 2010, 05:44:22 PM »
It seems to be working fine here. See the screen capture I took and posted on youtube.
http://www.youtube.com/watch?v=hI0_c_fuS28
Do you see the same when you view the Brain and work via the flyout screen?
Offline johnv
  •  43 43
« Reply #6 on: September 30, 2010, 06:24:35 PM »
Hood,
Yes! I get the same action. I shut down the system for about 5 minutes and rebooted.... It works fine now!   I hate when I can't find the cause of these malfunctions! Thanks again Hood.
Johnv
« Reply #7 on: September 30, 2010, 06:26:40 PM »
Hopefully it will keep working from now on :)
