Hello Guest it is September 24, 2026, 01:23:53 AM
Author Topic: license on 2nd computer/encoders  (Read 12616 times)
« on: September 26, 2010, 08:25:28 PM »
I downloaded license to mach3 folder on 2ND computer but it is still running in demo mode.I am running a second computer and monitor to display encoders . The encoders are on the stepper motors which are closed loop between the motors and drivers. Will encoders  show up for display even in demo mode? I will also use this computer for a back up and I am concerned that I can't retrieve the license agreement if something happened to the 1st computer. Thanks,Tommy
Re: license on 2nd computer/encoders
« Reply #1 on: September 27, 2010, 01:27:41 AM »
The licence is called Mach1Lic.dat and it needs to be placed in the main Mach3 folder, so check it is there and not in a sub folder.
« Reply #2 on: September 27, 2010, 07:39:54 AM »
Hood, Thats all it was.Thanks again,Tommy
« Reply #3 on: September 27, 2010, 07:50:56 AM »
No problem :)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #4 on: September 27, 2010, 08:25:21 AM »
And remember, if you are using your machines to generate a profit then you need to have one license per computer/machine pair.
Happy machining , Jeff Birt
« Reply #5 on: September 27, 2010, 10:59:47 AM »
I have 1 machine but am useing a 2nd computer to display encoders?
« Reply #6 on: September 27, 2010, 11:15:29 AM »
Thats fine, you can have Mach on as many computers as you like, if you are making money from the machines then you need a licence for each machine )lathe, mill, router etc)
