Hello Guest it is October 24, 2026, 11:16:00 PM
Author Topic: Which Servo controller is fitted with Mach3?  (Read 15251 times)
kingmeager
« on: October 24, 2006, 01:12:32 AM »
hi ,Which Servo controller is fitted with Mach3?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Which Servo controller is fitted with Mach3?
« Reply #1 on: October 24, 2006, 02:57:27 AM »
Mach uses external controllers, you can use any step and direction type you want.
Graham.
kingmeager
« Reply #2 on: October 24, 2006, 08:51:45 PM »
Dear Graham,
  I'm new for Mach3.I don't know where i can collect the Servo controller?
 Could you recommend to me?
 Best regards
« Reply #3 on: October 24, 2006, 08:57:47 PM »
Check these out. Hope it helps.
http://www.geckodrive.com/
kingmeager
« Reply #4 on: October 24, 2006, 10:25:46 PM »
Thanks.But i need AC Servo Controller.
« Reply #5 on: October 24, 2006, 10:40:14 PM »
www.a-m-c.com look at there Digi flex drives :) They are not cheap but they are GREAT drives!
www.newfangledsolutions.com
www.machsupport.com
