Hello
Guest
it is
October 24, 2026, 11:17:52 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Which Servo controller is fitted with Mach3?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Which Servo controller is fitted with Mach3? (Read 15253 times)
kingmeager
on:
October 24, 2006, 01:12:32 AM »
hi ,Which Servo controller is fitted with Mach3?
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Which Servo controller is fitted with Mach3?
Reply #1 on:
October 24, 2006, 02:57:27 AM »
Mach uses external controllers, you can use any step and direction type you want.
Graham.
Logged
kingmeager
Reply #2 on:
October 24, 2006, 08:51:45 PM »
Dear Graham,
I'm new for Mach3.I don't know where i can collect the Servo controller?
Could you recommend to me?
Best regards
Logged
Chaoticone
5,624
Precision Chaos
Reply #3 on:
October 24, 2006, 08:57:47 PM »
Check these out. Hope it helps.
http://www.geckodrive.com/
Logged
If you could see the things I have in my head, you would be laughing too.
kingmeager
Reply #4 on:
October 24, 2006, 10:25:46 PM »
Thanks.But i need AC Servo Controller.
Logged
Brian Barker
3,860
Reply #5 on:
October 24, 2006, 10:40:14 PM »
www.a-m-c.com
look at there Digi flex drives
They are not cheap but they are GREAT drives!
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
