Mach Discussion => General Mach Discussion => Topic started by: kingmeager on October 24, 2006, 02:12:32 AM
hi ,Which Servo controller is fitted with Mach3?
Mach uses external controllers, you can use any step and direction type you want.
Graham.
Dear Graham,
I'm new for Mach3.I don't know where i can collect the Servo controller?
Could you recommend to me?
Best regards
Check these out. Hope it helps.
http://www.geckodrive.com/
Thanks.But i need AC Servo Controller.
www.a-m-c.com look at there Digi flex drives :) They are not cheap but they are GREAT drives!
