Hello Guest it is October 21, 2026, 03:51:55 PM
Author Topic: Hello have a question about Mach 3, Windows 7 and the VCarve program  (Read 12889 times)
Hello,
I have Mach 3 and VCarve pro. I recently had to change my computer and I am having a slight problem with VCarve sending the files to Mach 3. On my old computer I had everything working fine, but when I try to send the file from VCarve to Mach 3, it says that it cannot find it.
Mach 3 works fine, I can move the machine and I can manually put in a file and run it. I was wondering if anyone else had this problem before.
I have already called VCarve and they made sure my settings are correct and then said it must be something with Mach 3.
Thank you
Don
Re: Hello have a question about Mach 3, Windows 7 and the VCarve program
« Reply #1 on: September 01, 2010, 08:56:53 PM »
What says it cannot find it?
You save a file from V-Carve Pro, and Open the File with Mach3?
Can you give a bit more detail of what the problem is?
« Reply #2 on: September 02, 2010, 09:41:16 AM »
I create a file in v-crave. then save the tool path.output all visible files is selected. Post processor is mach2/3 atc arcs inches txt,
output direct to machine is selected. driver mach. The select save toolpaths to file. I get a v-crave window to pop up that says Failed to find data on installed version of mach select ok and a new window pops up saying failed to find running instance of mach select ok then I open mach program go to load g- code and my file is there as a temporary file. I have tried running the file with the router turned of and raised above the work surface and it seems to work
« Reply #3 on: September 02, 2010, 10:51:04 AM »
I've never done the direct to machine, but it sounds like you don't have Mach3 running and it needs to be.
« Reply #4 on: September 02, 2010, 11:05:45 AM »
yes mach 3 is up and running As a personal habit I open both programs when I start working the minimize them when not in use.and I have always used direct to machine
Is there a better ,simpler or faster way?
