Mach Discussion => Mach3 under Vista => Topic started by: dfleming75 on September 01, 2010, 02:22:27 PM
Hello,
I have Mach 3 and VCarve pro. I recently had to change my computer and I am having a slight problem with VCarve sending the files to Mach 3. On my old computer I had everything working fine, but when I try to send the file from VCarve to Mach 3, it says that it cannot find it.
Mach 3 works fine, I can move the machine and I can manually put in a file and run it. I was wondering if anyone else had this problem before.
I have already called VCarve and they made sure my settings are correct and then said it must be something with Mach 3.
Thank you
Don
What says it cannot find it?
You save a file from V-Carve Pro, and Open the File with Mach3?
Can you give a bit more detail of what the problem is?
I create a file in v-crave. then save the tool path.output all visible files is selected. Post processor is mach2/3 atc arcs inches txt,
output direct to machine is selected. driver mach. The select save toolpaths to file. I get a v-crave window to pop up that says Failed to find data on installed version of mach select ok and a new window pops up saying failed to find running instance of mach select ok then I open mach program go to load g- code and my file is there as a temporary file. I have tried running the file with the router turned of and raised above the work surface and it seems to work
I've never done the direct to machine, but it sounds like you don't have Mach3 running and it needs to be.
yes mach 3 is up and running As a personal habit I open both programs when I start working the minimize them when not in use.and I have always used direct to machine
Is there a better ,simpler or faster way?
