Hello
Guest
it is
October 10, 2026, 01:06:40 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
max lines of code
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: max lines of code (Read 26889 times)
Picengraver
343
Re: max lines of code
Reply #10 on:
August 28, 2010, 05:59:59 PM »
I typically cut 600,000 lines (+ - a few) engraving lithophanes. Never a problem with Mach3 burping.
John Champlain
www.picengrave.com
moorea21
228
Reply #11 on:
August 28, 2010, 06:02:59 PM »
Lithophane... learn something new every day. Do you have pictures, or links to pictures? I'm curious to see what you do...
Rich B
ger21
6,295
Reply #12 on:
August 28, 2010, 06:08:43 PM »
If it comes out OK, I'll post a picture in an hour or so.
Picengraver
343
Reply #13 on:
August 28, 2010, 06:27:41 PM »
OK, trying to post a picture again - don't know what happened other two tries.
This is a smaller litho I did recently.
John Champlain
[attachment deleted by admin]
www.picengrave.com
Picengraver
343
Reply #14 on:
August 28, 2010, 07:12:09 PM »
Hope I haven't messed up this thread. I can not see anything but a solid blank screen on page 2 for some reason. Strange ?
John Champlain
www.picengrave.com
ger21
6,295
Reply #15 on:
August 28, 2010, 07:52:23 PM »
First Litho I ever tried.
derek
200
Reply #16 on:
August 29, 2010, 01:38:17 PM »
I've run over a million lines before on some large patterns. 30 - 40 hour continuous cut times with no problems. Unless of course you forget to turn off the tool path display before you load!
Derek
Print
Pages:
1
2
Go Up
« previous
next »
