Hello Guest it is November 18, 2026, 03:20:47 AM
Author Topic: twinned motors; 2 sharing 1 driver  (Read 29702 times)
« on: August 07, 2010, 04:47:43 PM »
I'm wondering what the problems are with wiring 2 steppers into 1 driver, and just doubling the current? I intend using a motor at either end of a long bike chain; the chain will hang very slack, and the 2nd motor is just there to stop one side of the chain clashing into the other.
The application for this is a revolving 'carousel' pen holder for a large plotter.
Only got 1 axis left in Mach, but 2 motors left in the box! It's tempting to try it, but there must be a reason nobody does it that way.
Rich B
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: twinned motors; 2 sharing 1 driver
« Reply #1 on: August 14, 2010, 04:12:04 AM »
This is generally not recommended - however, I've built several machines driving two steppers from one driver and it's worked very successfully. There are many factors which can make it a bad idea BUT generally speaking - success is inversely proportional to motor speed if that helps.
« Reply #2 on: August 14, 2010, 05:43:57 AM »
Thanks Stirling,
I had thought of splitting the signal from the controller to 2 drivers, each with it's own motor. Probably with a line driver before the split. Would that get round the potential inductance problems? Keeping speeds low would be fine, but so would knowing I'm not killing my drivers...
I may just drive the whole thing through a screw, as the weight is beyond what the motor would like, ie 7kg vertical lift, albeit at low speed. Also the holding torque woyuldn't matter, as the pitch of the screw would hold it. That way I only need to use the one motor.
If it doesn't work, I'll be back!
Rich B
Offline kf2qd
  •  157 157
« Reply #3 on: August 16, 2010, 09:34:56 AM »
2 drivers off of 1 signal is a much better solution than 2 motors off of 1 driver.
« Reply #4 on: August 16, 2010, 09:38:01 PM »
Mi controller is a Hobby CNC Pro 4axis , 3A max per axis, I want to drive small stepper motors from dot printers , that are  12volts 0.75A each,I need to drive two steppers in one axis for prevent racking and gat more torque.  I can't slave motors in X and A axis  because I need A axis for other use.  Iam thinking if is possible  drive this two motor in  one axis considerating that current in both motors in less that total current in one axis. I have fear principally to damage chips in controller doing this.
Do you think that this can burn my controller? Or bad results could be only lost steps and other minor problems?
Thanks in advance for your help.
Rene
Offline stirling
  •  2,188 2,188
  • UK
« Reply #5 on: August 17, 2010, 05:34:46 AM »
There's some stuff on cnczone by Marris and others about this but I can't find it at the moment. I seem to remember though that it went something like this: Stepper motors don't play well together off one driver. If you keep speed down to no more than two revs/sec then it'll probably be ok. Otherwise oscillation will occur and one motor is likely to draw all the current and the other will stall.
Now Marris has no doubt forgotten more about stepper systems than I'll ever know, BUT - as I've said above I've done this on several of my systems and never had a problem and that was with the motors doing up to about 10 revs/sec. Maybe geckos are even better than Marris thinks!
Personally I can't think of any reason why your drivers should be at risk but it's ultimately your choice.
Well as I've tried to say - that depends. Are you for example suggesting that I should buy a fourth driver at over $100 a time for each of my systems that work perfectly well with three?
Ian
Offline rcaffin
  •  1,073 1,073
« Reply #6 on: August 17, 2010, 06:25:09 AM »
In principle, it electronic terms, it is a BAD idea. You cannot get the motors to share the current properly.
However, if you want to try this, and each motor has 4 phases + common, then up the voltage a little bit and put a power resistor in series with each motor. Not perfect, but tolerable up to a point (determined by experiment!).
If the windings are being driven in push/pull (ie no common), then don't do it. Bad karma.
« Reply #7 on: August 17, 2010, 06:33:03 AM »
Why not slave it with another axis (A or B) then?
« Reply #8 on: August 17, 2010, 07:08:22 AM »
Mi controller has only four axis , and I need A axis for other purposes, Iam trying to use small stepper motor from printers, using two I can prevent racking and get more torque.
 2 rev sec is 120 rev min, I will use a 11 mm pulley then  at 100 rpm  I will  get 100 * 11 *3.14 = 3454 mm/min
is faster that I need.
My steppers are unipolar 8 wires,
RCAFFIN please, could you send me a diagram of suggested connections?
Thanks in advance for your help, other advices will be well received.
Regards
Rene
Offline stirling
  •  2,188 2,188
  • UK
« Reply #9 on: August 17, 2010, 07:53:17 AM »
There is absolutely no need to do this. And he's said they are 8 wire motors. Just wire the motors how you like - serial bipolar, single coil bipolar or parallel bipolar whichever suits your application and then wire the two motors in parallel to the driver. As long as your combined rated current is what your drive is set to *source* you won't be current *starving* your motors. But BTW - even if the calculated current "draw" of your motors was MORE than your driver can source you won't damage anything - your driver is a chopper drive - it will NOT source more current than it is set to source - but of course you would then be current *starving* your motors.
No, your motors are not unipolar motors, they are 8 wire motors - there is a difference. They can be *wired* unipolar or of course bi-polar.
« Last Edit: August 17, 2010, 08:20:01 AM by stirling »
