Hello Guest it is November 22, 2026, 07:36:55 AM
Author Topic: blue screen of death  (Read 25882 times)
JDolecki
« on: October 19, 2006, 09:56:55 PM »
Here we go again. What causes the blue screen of death when you load Mach 2/3?
I need to sort out my touch screen but i cant get around this. I tried uninstalling the drive serval times and reloading mach also but i just cant figure it out. im sure is something simple.  I'm running win200.
any ideas would be appreciated.
Yodawill2000
Re: blue screen of death
« Reply #1 on: October 20, 2006, 08:01:59 AM »
Not at all a Mach guru but Ive been in the PC service biz for EON's.
It should have a filename or error code that its having issues with in the Blue screen.
Write that down and post it here.
« Reply #2 on: October 21, 2006, 04:02:33 PM »
I see that you didn't reboot :)
You need to uninstall the driver and reinstall. Be sure that you reboot the computer after you insall
www.newfangledsolutions.com
www.machsupport.com
JDolecki
« Reply #3 on: October 22, 2006, 10:07:12 PM »
I reboot all the time. but still no luck.
When the blue screen flashes the screen is only up for a few seconds, is there a way to freeze the screen so i can read it.
« Reply #4 on: October 23, 2006, 01:18:01 AM »
Its been a while since I used W2K but I think its the same as in XP so heres what to do.
Go to Control panel in windows then system then click on the advanced tab then select the settings button in the start up and recovery part of the page you will then be able to take the check out of the automatically restart option. This should then allow you to see the windows error message.
Yodawill2000
« Reply #5 on: October 23, 2006, 07:37:03 AM »
Hood beat me to it   ;D
That is correct.
JDolecki
« Reply #6 on: October 23, 2006, 09:51:50 PM »
The screen still flashes off after changing the reboot setting. But it did say the error was saved to a system event log in Control panel/Adminstrative Tools/ Event viewer/ System. So I hope this might be the message. So here ya go.
The computer has rebooted from a bug check. The bug check was.
0x000000le (0xc0000005 , 0xfce4a7bf , 0xc03ef0f8 , 0xc03ef0fc)
Microsoft Windows (2000) v15.2195
A dump was saved in C:\WINNT\Minidump\mini\102306-02.dmp
Any ideas would be appreciated.
Thanks John
« Last Edit: October 23, 2006, 09:55:10 PM by JDolecki »
JDolecki
« Reply #7 on: October 24, 2006, 03:41:42 AM »
the previous post was the message i got out of the event log file.
Once i removed symantec pc anywhere the computer no longer shut down and the blue screen stayed up. Here is the current message im working on.
Stop 0x0000001e (0xc000005 , 0xfce4a7bf , 0xc03eee78 , 0xc03eee7l )
Adress FCE4A7BF  Base FCE48000
Datestamp 428e9757
Kmode- exception not handled.
Beginning of physical dump.
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
« Reply #8 on: October 24, 2006, 04:09:11 AM »
Boy, I hate to say this but it might be faster to back up and do a fresh install. I know this sucks but you could spend forever trying to track that down.
At least with a fresh install you will be able to keep looking for the lock up as you re install your apps, then you would know what one is not getting along with mach..
CHad
JDolecki
« Reply #9 on: October 24, 2006, 06:34:32 AM »
Actually is becoming a good learning experence. So i dont mind doing it.
