Hello Guest it is October 25, 2026, 06:05:08 AM
Author Topic: Geckp 540 and Solid State Relay  (Read 15494 times)
« on: July 16, 2010, 10:22:08 PM »
Good Evening Everybody.
I have been searching the boards for a good 3 hours trying to figure out how to wire and configure this realay and finally had to ask for help.
I have a gecko 540 and a Fotek SSR-25 DA Solid State Relay.  48 VDC Input and 24-380V VAC Output.  I have connected the - side of the relay to the Gecko on Pin 5 of the main terminal board, and the + side to the 48VDC + Terminal.  I have wires coming from the VAC side to an electrical outlet.   If anybody could please help me get mach 3 setup in Mach3, it would be much appreciated.
David
  •  9,374 9,374
Re: Geckp 540 and Solid State Relay
« Reply #1 on: July 17, 2010, 03:53:20 AM »
David,
Don't know if this is any help but this is the typical SSR configuration.
« Reply #2 on: July 17, 2010, 06:57:54 AM »
Hi David,
I believe it should be wired like this diagram as this is how I have mine wired. The leads in the diagram that go to the breakout board (your G540) are the "TO COMPUTER" leads in the picture. The + goes to output 5 or 6 on the G540 and the other goes to ground of the parallel port as well.
The credit of this diagram goes to Tom Benedict's relay tutorial, which I HIGHLY suggest you read before continuing.
http://www.cartertools.com/tbbrb.html
Hope this helps, but ALWAYS be careful with any wiring!
« Reply #3 on: July 20, 2010, 09:36:11 PM »
THanks for the input, I actually bought a new relay, a dual relay board from easycnc.com.  It has all the right hookups to make it work right.  I hope I can control both my spindle, and using the mist relay port to turn on my dust collector system.
  •  9,374 9,374
« Reply #4 on: July 21, 2010, 01:04:01 AM »
Crash,
Just one point of note:-
If you take a power tool apart you will usually notice an R/C or inductive suppression device fitted across the on/off switch. This is there to reduce the arc (which occurs during switching) and provides a fair degree radio frequency suppression. If you encounter any problems, with computer glitches etc, using your relay board then would be a good idea to fit one of these suppression devices across the contacts of each relay.
(SSR’s, on the other hand, make use of the 'zero crossing point' of the a/c waveform for their on/off switching points, this reduces the spike / noise / arc to an absolute minimum and no other forms of suppression are usually necessary).
