Mach Discussion => General Mach Discussion => Topic started by: crash5050 on July 16, 2010, 11:22:08 PM
Good Evening Everybody.
I have been searching the boards for a good 3 hours trying to figure out how to wire and configure this realay and finally had to ask for help.
I have a gecko 540 and a Fotek SSR-25 DA Solid State Relay. 48 VDC Input and 24-380V VAC Output. I have connected the - side of the relay to the Gecko on Pin 5 of the main terminal board, and the + side to the 48VDC + Terminal. I have wires coming from the VAC side to an electrical outlet. If anybody could please help me get mach 3 setup in Mach3, it would be much appreciated.
David
David,
Don't know if this is any help but this is the typical SSR configuration.
Hi David,
I believe it should be wired like this diagram as this is how I have mine wired. The leads in the diagram that go to the breakout board (your G540) are the "TO COMPUTER" leads in the picture. The + goes to output 5 or 6 on the G540 and the other goes to ground of the parallel port as well.
The credit of this diagram goes to Tom Benedict's relay tutorial, which I HIGHLY suggest you read before continuing.
http://www.cartertools.com/tbbrb.html
Hope this helps, but ALWAYS be careful with any wiring!
THanks for the input, I actually bought a new relay, a dual relay board from easycnc.com. It has all the right hookups to make it work right. I hope I can control both my spindle, and using the mist relay port to turn on my dust collector system.
Crash,
Just one point of note:-
If you take a power tool apart you will usually notice an R/C or inductive suppression device fitted across the on/off switch. This is there to reduce the arc (which occurs during switching) and provides a fair degree radio frequency suppression. If you encounter any problems, with computer glitches etc, using your relay board then would be a good idea to fit one of these suppression devices across the contacts of each relay.
(SSR’s, on the other hand, make use of the 'zero crossing point' of the a/c waveform for their on/off switching points, this reduces the spike / noise / arc to an absolute minimum and no other forms of suppression are usually necessary).
