Hello
Guest
it is
November 11, 2026, 05:16:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
Mach Screens
Machscreen Screen Designer
(Moderator:
Klaus1311
Add image is under background
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Add image is under background (Read 45051 times)
ger21
6,295
on:
June 29, 2010, 07:16:06 PM »
I want to add an image of some text, but it's hidden behind my background image. I can swap it with the background and it shows up, but it messes up every other element on the screen. Is there a way to bring an image to the top? Tried copying and pasting, but they all end up under the background image.
Klaus1311
531
Re: Add image is under background
Reply #1 on:
June 30, 2010, 02:27:53 AM »
Hi Gerry,
the display order is bitmaps, leds, image buttons, controls, all from largest to smallest size. If you place controls which overlap, you can select those and use edit -> "swap layer".
Klaus
The brain isn't a soap, it doesn't shrink when used.
Klaus1311
531
Reply #2 on:
July 01, 2010, 10:04:09 AM »
Hi Gerry,
did my suggestions help solve your problems?
Klaus
ger21
6,295
Reply #3 on:
July 01, 2010, 10:47:22 AM »
No, I mentioned in my original post that I can't swap layers, because it messes up the display of all the other controls. It would work if I added the images at the start, before adding other controls.
I can use an LED instead of an image and that should work though. I've used this method before on my Aqua screen.
Klaus1311
531
Reply #4 on:
July 01, 2010, 10:55:49 AM »
Hi Gerry,
do you still have the screen with the messed up controls. I you could send the set-file I will have a look at it.
Klaus
ger21
6,295
Reply #5 on:
July 01, 2010, 06:22:12 PM »
I swapped the layers again to get back to normal. Right now I'm in the middle of a bunch of changes. When I get a chance, I'll see if I can duplicate it. If so, I'll let you know.
hacker77
34
Reply #6 on:
May 15, 2014, 10:38:14 AM »
Gerry,
Did you ever figure this problem out? As I am having the exact same issue.
ger21
6,295
Reply #7 on:
May 15, 2014, 10:44:20 AM »
Sorry, but I have no recollection of what I was doing.
I went back to using Screen4, and only use a single background bitmap on my screens. Multiple bitmaps have always had issues for me.
hacker77
34
Reply #8 on:
May 15, 2014, 10:51:29 AM »
Thanks for the quick reply! I guess I'll email Klaus about it.
Thanks again.
Klaus1311
531
Reply #9 on:
May 16, 2014, 05:45:14 AM »
Hi Hacker77
sending me the files generated by "Project Export" would be helpful, in that case I would have your MachScreen Settings.
Klaus
Print
Pages:
1
2
Go Up
« previous
next »
