Hello Guest it is November 22, 2026, 07:07:21 AM
Author Topic: master cam to mach3 turn  (Read 33627 times)
Offline jve
  •  128 128
Re: master cam to mach3 turn
« Reply #10 on: June 30, 2010, 11:57:23 AM »
i notice that in mach3 turn when i bup up the feed rate while it is in g1 it will set after a g0 do you know why ?
No FRO on Queue option set?
i did try it but with no luck the only thing that i set was (look ahead 20lines) i adjust it to 1 and then after that code line it will bup up but you still have to wait for the other line then
« Reply #11 on: July 01, 2010, 03:07:31 AM »
Can you attach your xml please.
Offline jve
  •  128 128
« Reply #12 on: July 01, 2010, 11:40:20 PM »
how can i upload a XML file i made a copy with a pendrive but i dint know how to upload in the forum  page
Offline jve
  •  128 128
« Reply #13 on: July 01, 2010, 11:54:37 PM »
i think here is the file
« Reply #14 on: July 02, 2010, 06:29:31 AM »
Ok first thing is uncheck No FRO on Queue
Then if it still doesnt work then I think you may have an issue with the screenset as I can adjust the FRO no problem with my own screenset but the standard Turn one doesnt seem to work.
Will have a look see if I can find the issue with the standard screenset.
« Reply #15 on: July 02, 2010, 06:41:22 AM »
Ok seems to be the OEM for increment feedrate that the turn screen uses are acting weird. On my screen I use OEM108 and OEM109 and it works as it should so try this screenset and see if it works.
Offline jve
  •  128 128
« Reply #16 on: July 03, 2010, 07:32:49 AM »
dear hood
it worked perfect !!!!!!!!!
many thanks for your help
« Reply #17 on: July 03, 2010, 07:53:55 AM »
No probs, will note this down and make sure that when/if Brian ever gets on to Rev4 Turn it will be fixed.
