Hello Guest it is November 22, 2026, 07:07:10 AM
Author Topic: master cam to mach3 turn  (Read 33625 times)
Offline jve
  •  128 128
« on: June 27, 2010, 03:20:08 AM »
dear guys
i am trying to work with the mastercam and posting in mach3 turn and i have a problem when mastercam generate the gcode G02,G03 in mach3 turn they are coming up circles i tryed to change the i,k to absolute but the problem keep coming up the difference is when i change I,K from absolute to incremental the circles come big or small any one is useing mastercam to mach3 turn so can help me !!!!!!!!!
Re: master cam to mach3 turn
« Reply #1 on: June 27, 2010, 07:05:03 AM »
Config menu, Ports and Pins, Turn Options then change the Revered Arcs in Front Toolpost.
Offline jve
  •  128 128
« Reply #2 on: June 28, 2010, 05:49:48 AM »
you bet hood
but i still have a problem mastercam is posting in radius with the mach3B post and when i change the post to fanuc it is ok posing in diameter but fanuc instead or i,j they use r so in mach3 they will come out circles
i need a mach3 post for mastercam that post in diameter
can some one help me !!!!!
« Reply #3 on: June 28, 2010, 06:43:15 AM »
Strange, I work in Dia mode and use R for arcs and its fine, did you try changing the reversed arc setting again after you used the new post processor?
Can you attach a bit of code that you have issues with and I will see how it looks for me.
Offline jve
  •  128 128
« Reply #4 on: June 28, 2010, 01:30:44 PM »
dear hood
belive it or not now it is posting in diameter and it is a fanuc prosesor and mach3 is fine with it
but dont ask me what i did cause i dont know
do you use mastercam to generate gcode?
« Reply #5 on: June 28, 2010, 04:53:13 PM »
Thats god to hear :)
No dont have MasterCAM.
« Reply #6 on: June 28, 2010, 08:53:17 PM »
Hmm....
You just shook the memory here, i don't use MasterCam, but Dolphin has a few different post processors for the
lathe, ie one for radius and one for diameter.  So may be similar. Additionaly check if there is a turning mode that you can be in
when bringing in the file as that could just be a click and you may have mistakenly done it.
FWIW,
Offline jve
  •  128 128
« Reply #7 on: June 29, 2010, 04:13:23 AM »
Dear rich
yes you might be wright
im just exploring the mastercam it is a bit complicated compare to the lazy turn but it is a verry good cam and also i need to practice alot
i notice that in mach3 turn when i bup up the feed rate while it is in g1 it will set after a g0 do you know why ?
i really apritiate your reply also hood cause when i have problems you allways find me an aswer thanks alot guys
« Reply #8 on: June 29, 2010, 04:54:30 AM »
No FRO on Queue option set?
« Reply #9 on: June 29, 2010, 03:36:15 PM »
I don't know if this is the same problem i had but latest version of mach would take all the radius moves and make circles out of them or a figure 8 i had to delete that version and go backwards in version's to correct the problem working fine now.
Dennis
