Hello Guest it is October 30, 2026, 11:52:25 AM
Author Topic: Anyone running a CNCshark with Mach3?  (Read 9723 times)
Offline Greolt
  •  956 956
« on: June 04, 2010, 05:39:13 AM »
I believe it is using an NCpod which should be no problem to run with Mach.
Greg
  •  9,375 9,375
Re: Anyone running a CNCshark with Mach3?
« Reply #1 on: June 04, 2010, 07:41:31 AM »
Hi Greg,
I thought the CNCshark was USB driven.
If you can you get access to the driver card for parallel connection then I think it would be possible to drive the machine from Mach3.
Offline Greolt
  •  956 956
« Reply #2 on: June 04, 2010, 07:53:48 AM »
Yes it is USB driven.
As far as I know it is using an NCpod.  Mach has a plugin for that.
In theory it should just be a matter of plug it in and go. I have used NCpod in the past.
Just wondered if any body was doing it.
Greg
