Hello Guest it is October 20, 2026, 03:59:46 PM
Author Topic: Homing and move off of switches.......?  (Read 11846 times)
« on: May 15, 2010, 11:28:27 AM »
Hi folks,
Quick question. The issue may or may not be with Mach3. (version download / installed May 2010 running in WinXP SP2).
When I press the Ref All button, all 3 axis move to their respective home position and move off the switch a small amount. The Z axis moves enough to reverse state of the M3Home switch (LED is off on the diagnostics screen). The X and Y LED's are still active even though a slight move occurred off the limit switch. If I jog further in both X & Y the LED's will change state. Soft Limits is engaged and working.
I will say that the distance moved off the switch in Z is greater than the distance moved off the X & Y switches.
Everything else in Mach3 seems to work regardless of this issue, just something that bothers me. Is there a setting that I / OEM missed to setup?
Any thoughts or suggestions.
John
Re: Homing and move off of switches.......?
« Reply #1 on: May 15, 2010, 11:47:57 AM »
You may be seeing noise. You can try increasing the debounce setting in General Config. Try 2000-3000.
Also, try homing at a lower speed.
« Reply #2 on: May 15, 2010, 09:56:49 PM »
I checked the settings on the machine and there are 2 fields - "Debounce Interval" and "Index Debounce" both with a value of 10.
What value in which field???
John
« Reply #3 on: May 15, 2010, 11:00:45 PM »
Debounce Interval. Try 2000.
