Hello
Guest
it is
October 23, 2026, 04:28:09 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Problems with xyz axis needing constant recalibration
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problems with xyz axis needing constant recalibration (Read 10299 times)
nickold
2
on:
May 01, 2010, 03:33:04 AM »
Can any tell me why I would need to keep calibrating the xyz axis. Works perfectly for a while and then goes haywire. Machine is a simple xyz milling machine. Do I need to license the software to stop this?
Logged
Carnoustie, Scotland
Re: Problems with xyz axis needing constant recalibration
Reply #1 on:
May 01, 2010, 03:41:28 AM »
What do you mean by losing calibration?
Logged
Reply #2 on:
May 01, 2010, 06:40:36 PM »
Once you have your motor tuning / configuration done should not need to do anything.
Logged
Print
Pages:
1
Go Up
« previous
next »
