Hello Guest it is October 23, 2026, 04:26:39 AM
Author Topic: Problems with xyz axis needing constant recalibration  (Read 10296 times)
« on: May 01, 2010, 03:33:04 AM »
Can any tell me why I would need to keep calibrating the xyz axis.  Works perfectly for a while and then goes haywire.  Machine is a simple xyz milling machine.  Do I need to license the software to stop this?
Re: Problems with xyz axis needing constant recalibration
« Reply #1 on: May 01, 2010, 03:41:28 AM »
What do you mean by losing calibration?
« Reply #2 on: May 01, 2010, 06:40:36 PM »
Once you have your motor tuning  / configuration done should not need to do anything.
