Hello Guest it is October 20, 2026, 12:18:56 PM
Author Topic: Homing slaved axis  (Read 9408 times)
Homing slaved axis
« on: April 10, 2010, 05:33:04 PM »
Hi all...
On a gantry machine if I have and X and A axis and I use RefCombination(9), will it home the first switch to hit home then the other switch?   Or will it always home the X first then the A?  If the latter is true, I'm wondering what happens if the A switch hits home first.  Seems that it would over-run the A switch a little and home the X, but then with the A switch already activated, how would it then home the A side?  I'm considering changing to a two motor system and want to make sure I understand how slaving works.
Thanks very much.
Re: Homing slaved axis
« Reply #1 on: April 10, 2010, 08:19:46 PM »
They home at the same time, but independently.
