Hello Guest it is November 22, 2026, 01:29:56 PM
Author Topic: DRO display wrong in diag. screen only  (Read 24888 times)
« on: April 09, 2010, 09:34:07 AM »
When I am in the run program, MDI, Tool Path and settings screen the DRO is correct for the appropriate axis. (x=x, y=y, z=z)  In the diagnostic screen movement in X axis shows up show up as movement in the A axis DRO is this a glitch or is there a place to assign axis in the diagnostic screen only.
Thanks for helping
Greg
Re: DRO display wrong in diag. screen only
« Reply #1 on: April 09, 2010, 01:43:34 PM »
It sounds like it may be a screen problem, are you using the standard screen?
« Reply #2 on: April 09, 2010, 03:47:03 PM »
no I am using plug-ins from CandCNC for custom screens. Don't know why that would make a difference.
« Reply #3 on: April 09, 2010, 03:50:38 PM »
The screenset is likely to have the wrong oem code assigned to the DRO, if you either tell me where to download the screenset or attach it here I will have a look.
« Reply #4 on: April 09, 2010, 05:16:29 PM »
here is the screen set I am currently using thanks for looking
« Reply #5 on: April 09, 2010, 05:25:03 PM »
Try loading this one, they had X DRO as C and A DRO as X.
« Reply #6 on: April 09, 2010, 06:02:19 PM »
Thank you that works perfectly
« Reply #7 on: April 09, 2010, 06:15:30 PM »
No problem :)
« Reply #8 on: April 09, 2010, 07:35:51 PM »
Hood I may have spoke to soon, I first loaded it in my test mach 3 on my lap top. When I loaded on the control computer in the shop I noticed that the velocity still shows up in A but the DRO displays in X correctly. thank you so much for your help.
« Reply #9 on: April 10, 2010, 02:12:01 AM »
Just to be clear, you are seeing the Velocity in the A  DRO? by Velocity are you meaning feedrate? And this is on the Diagnostics page?
