Hello Guest it is October 22, 2026, 09:58:22 PM
Author Topic: New Fixture save  (Read 71529 times)
New Fixture save
« on: October 06, 2006, 11:21:58 AM »
Is anyone else having problems with Mach not asking whether you want to save "new fixture" when shutting down?
If  I just open Mach, home, move to any position and zero the axis then shut Mach down it will ask but if I load any code whatsoever I will not be asked whether I want to save the new fixture even though I have changed the offset.
Re: New Fixture save
« Reply #1 on: October 06, 2006, 04:32:35 PM »
Do you have you optional offset save and persistant offsets check boxes checked in config-state screen.
« Reply #2 on: October 06, 2006, 04:34:38 PM »
Yes, sorry should have said that in my post :(
« Reply #3 on: October 06, 2006, 04:47:27 PM »
I thought you would have. 8)
I'm assuming you
1. Load your code
2. Jog to where you want zero to be
3. Zero your axis dros.
Do I understand this?  ??? From this point, if you shut Mach down it should but does not ask for fixture save. Any time I have zeroed my axis, from that point on, when I shut Mach down it ask for fixture save.
« Reply #4 on: October 06, 2006, 04:52:50 PM »
Yes thats exactly what I am meaning, just you are a bit more eloquent ;)
This is happening on all the computers I have Mach on, the mill, the workshop computer and the home computer.
« Reply #5 on: October 06, 2006, 05:20:49 PM »
Interesting thing is I have just tried going back to previous versions, when I install 1.90.017 it works perfectly but my screen doesnt show properly as this version preceded the new LED style support. The next version I have is 1.90.035 and this doesnt work as far as the new fixture is concerned. Also any version after this does not work.
« Reply #6 on: October 06, 2006, 05:29:08 PM »
As a wise man told me, and I quote ( It's Arts fault, it allways is) ;D
« Reply #7 on: October 06, 2006, 05:33:06 PM »
I saw that LOL
« Reply #8 on: October 06, 2006, 05:46:10 PM »
Has this been resolved?, I am having the same problem ver 1.84.001 optional offsets are checked as is persistant
« Reply #9 on: October 06, 2006, 06:00:21 PM »
Only way I can resolve it at the moment is go back to version 1.90.017
 This is strange because I have been using later versions for a long time but it is only recently that I have been getting this problem. I am wondering if an upgrade to a later version has changed something and going back the way is not overwriting that something. This then begs the question of why 1.90.017 works for me, I am confused, but thats a normal state of mind for me ;)
