Hello Guest it is October 02, 2026, 04:24:58 PM
Author Topic: inf lazycam 2.64 mach3 rc2.0.g  (Read 29224 times)
« on: October 04, 2006, 09:01:11 AM »
need info on new upload
my problem is when i generate g code with lazycam it generate like this
c:\mach3\gcodef09.nc
it should be
c:\mach3\gcode\f09.nc
Re: inf lazycam 2.64 mach3 rc2.0.g
« Reply #1 on: October 04, 2006, 10:01:48 AM »
Okay that will be done next week after i get back from the trip :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: October 04, 2006, 10:09:14 AM »
hi find some think it look like if i generate the gcode and change the directory it mist  the \
thank you
« Reply #3 on: October 06, 2006, 05:48:35 PM »
hi brian
soon you fix the problem let me know and put on ftp
thank you
jacques
« Reply #4 on: October 12, 2006, 05:15:02 PM »
allo brian
not fiend the problem on lazycam
thank you
jacques
« Reply #5 on: October 14, 2006, 03:30:53 PM »
There is work being done on it now :)
www.machsupport.com
« Reply #6 on: October 14, 2006, 06:54:46 PM »
Don't know what to tell you.. I can get it to break  ???
Could you post the file and your XML?
Brian
www.machsupport.com
« Reply #7 on: October 16, 2006, 05:48:01 PM »
this 2 file the original and after
the original it ok save at c:\mach3\gcode\
and after i change dir like C:\mach3\gcode\demo
it mist the \ after demo and save like this c:\mach3\gcode demof34.nc
so the file is demof34.nc it should be in file c:\mach3\gcode\demo\   and name f34.nc
you gone to find in the xml file after  place to save it mist   the  \   after c:\mach3\gcode\demo  <-----------
thank you
Jacques
« Reply #8 on: October 16, 2006, 05:54:54 PM »
sory this is the one after i change dir
thank you
jacques
« Reply #9 on: October 21, 2006, 05:59:52 PM »
hello
still not find the problem about the  \  missing
thank you
jacques
