Hello Guest it is November 01, 2026, 10:13:26 AM
Author Topic: inf lazycam 2.64 mach3 rc2.0.g  (Read 29544 times)
Re: inf lazycam 2.64 mach3 rc2.0.g
« Reply #10 on: October 25, 2006, 10:50:20 PM »
I will test it in the next few days now that I have your XML
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: November 15, 2006, 07:01:11 PM »
allo Brian
on lazcam 2.66 still missing  the    \   when we change in gcode file options it lose the   \
thank you
« Reply #12 on: November 17, 2006, 09:14:36 PM »
I have tested for that and I can't get it to post wrong :( there is something that we are missing and at some point it is going to show up!
Any one have this happen?
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #13 on: November 17, 2006, 09:54:30 PM »
Hi, Jlautomatio & Brian
If Mach3 & LC reside in other than Mach3 folder, like Mach3R2.0.010.
The Gcode post's to Mach3R2.0.010\ gcodetest55Dotpolyline.tap, rather than Mach3R2.0.010\gcode\test55Dotpolyline.tap.
Need's a back-slash gcode " \" test55Dotpolyline.tap is missing.
Thank's Chip
« Reply #14 on: November 18, 2006, 07:20:07 AM »
Okay that is two of you with the same problem :( I still can't get it to happen here! That makes it very hard to fix... I think that I will have to recode that section and see if i fix it by luck..
www.machsupport.com
« Reply #15 on: November 18, 2006, 07:53:24 AM »
this is small video  to see the problem
« Reply #16 on: November 18, 2006, 12:51:40 PM »
hi Brian
on ver 2.66 you change------------ layer control---------------- for ------------auto clean setting -------------------?????
how we put all the inf we use to put on layer control it was easy on the first one
thank you jacques
« Reply #17 on: November 19, 2006, 10:03:58 AM »
you can change the settings at the bottom of the screen :) There should be a video showing how to do this...
Take a look at the video and if you have any problems or questions I am here
thanks
Brian
www.machsupport.com
